Let's make a really quick detour and go over some details with your meter.
These tips will help us in the troubleshooting we will need to do, and may allow us to realize that perhaps we have an incorrect reading from before.
Take a look at your numbers on the gauge for your device. You have your green numbers at the top for resistance, and you have 3 rows of black numbers for AC/DC voltage and DC Current in mA.
This is the part that takes some getting used to.
The value you set on your meter, for example DC V 250. This is the maximum reading you can take that will make the needle move to the furthest right-most position. The numbers read for this is simply the set of numbers that ends with 250.
The tricky part is when you use a setting that has no matching set of numbers... for example DC V 2.5, you use the set of numbers that ends with 250.... I know it may sound odd, but pretend there is a decimal point there and the range becomes 0 - 2.50
There is one more tricky part... setting the meter to 300, because there is no range that will directly match 300... You have to use a little math, and use the set of numbers that ends with something you can easily multiply to get your answer...
Other than that, you have your resistance settings, Rx10 requires you to multiply the reading in the green set of numbers by 10 to get your value, and Rx1k requires you to multiply the reading by 1000. The small dial on the left is to calibrate your resistance readings which will require to to measure a known value resistor and adjust till the needle lines up with the right value.
I'm going to go over some of the past posts and see if we missed anything.
