Hi
Thanks For all the assistance before.
I am trying to build an automatic solar charge control that can charge a 100Ah lead acid battery and I have a 135watt solar panel. I have searched the net and I have built numerous circuits but, they don't seem to work the way it supposed to work. I am from south Africa and I am not sure if the components are different resulting in this outcome. Could you please provide me with a circuit diagram as well as a list of components that I will require. I need the circuit to be as simple as possible but must be able to charge the battery and also not overcharge as well as be able to maintain a float charge when the battery is full. This circuit must have an input for the solar panel and an output for the battery and a LED to display charging and float but it is important that it does not need any adjustment. Just something that I can build and plug the input and output and let the circuit do the charging.
I require another circuit but let me build this one then if you can maybe assist me with the other circuit.
I thank you again for the help.
