C
Chris Carlen
Hi:
Off-topic electronics question:
1/f noise density is asymptotically approaching infinity towards 0Hz.
Then why isn't measured noise infinite in reality? It seems this would
imply that a stable DC amplifier is impossible. That one should measure
random output fluctuations limited only by the rails. Yet this is not
seen. Why? If not, then there effectively must be some horizontal
asymptote to the 1/f noise distribution.
I want to compute the RMS noise for an instrument amp with DC-20kHz BW
for instance. What noise density do I use? The 1/f corner frequency
value? For an LT1167 example, with G=1 this is about 100nV/(Hz^0.5), so
I'd come up with about 14uV.
But I am unsure if this is the right noise density value to use.
Comments appreciated.
Good day!
_______________________________________________________________________
Christopher R. Carlen
Principal Laser/Optical Technologist
Sandia National Laboratories CA USA
[email protected] -- NOTE: Remove "BOGUS" from email address to reply.
Good day!
