I am building a burner for a ceramic smoker using a 1100w burner. My problem is the manufacturer switch will not let the burner stay on enough to keep the wood smoking. I believe this is because it is an infinite heat switch that turns off and on and when inside the smoker it is hot enough that it just heats up and will not stay on hot enough to create smoke.
I removed the switch from inside and hooked up a space heater switch in an electrical box to control it. I'm not sure it is working any better though.
Am I wrong using an infinite heat switch? Would a rheostat (if I could find one) work?
