Terminal Block vs. Soldering
Lei Reyes
Jul 2, 2014
60
Jul 2, 2014
60
Hi guys, just want to know when to prefer soldering over using a terminal block when connecting wires? And vice versa . Does it have something to do with the length of the wire that you are connecting ?
14,268
14,268
for me an easy test point
1) a place where meter probes can access the circuit
2) a place where cables between circuit sections can easily be disconnected to isolate one section from another
Lei Reyes
Jul 2, 2014
60
Jul 2, 2014
60
how about the transmission of data between the wires connected by the terminal block or the soldered one? Which do you think will better allow the transmission ?
14,268
14,268
what sort of signals and what frequency ?
Gryd3
Jun 25, 2014
4,098
Jun 25, 2014
4,098
Personally, if it's hard to reach or will never need to be serviced, I solder it.
If I am working on something that is 'modular' in nature, I put any modular components on a terminal block. Makes testing and replacing nodes much easier.
Overall though, it depends on the purpose... The physical location, environment, and the signal/power you are dealing with.
