D
D Yuniskis
Hi Joseph,
Ah, that's good. Still has ties to CW but it's different enough
to force people to think about it -- instead of blindly assuming
they know what it means. I am always amazed at how often I see
people doing this "the wrong way" -- even folks who *should* know
better (EE's, electricians, etc.)
Hi John,
No, you're still missing the distinction! The direction the wireJohn said:On Mon, 08 Mar 2010 13:07:14 -0700, D Yuniskis
Hi Joe,
J.A. Legris wrote:
[email protected] wrote:
nospam wrote:
[hmmm... that begs the question: what term to use
to refer to describe the "side" (direction) that you
turn *into*? E.g., what I have called "right" in
this example]
The side into the wind would be "windward" side, so the other side
would be "leeward". ;-)
wise *ss! :>
My question is serious: how do you refer to the "clockwise
side" of something? etc.
CW to the right, CCW to the left. In 2-D algebraic geometry CW is
negative angular displacement and CCW is positive.
Yes, I know CW from CCW. :>
What I was getting at is how do you concisely (ha! me and concise,
what an idea! :> ) refer to the situation I was describing above.
I.e., you wrap a wire around a screw/post clockwise so that
tightening the screw draws the wire around the screw *with*
the screw's motion. How do you describe the "initial placement"
of said wire? I.e., it wants to be "to the left" <frown>
of the post (but left and right have no meaning in this
context; and clockwise/counterclockwise only refer to
the direction in which you *wrap* the wire -- not *place* it!)
For example, placing the wire such that tightening the
screw *frays* the individual strands is A Bad Thing.
How do you refer to the "side" of the screw that causes
this result? (without saying "wrap the wire around the post
in a clockwise manner" -- since some wires are NOT
wrapped around a post ... e.g. solid wire that under some
sorts of connectors)
*approaches* the screw from plays a role. E.g., Red Right Return
is different from Red Right Depart! :>
So, you have to think in terms of the tip of the wire in
relationship to the balance of the wire. I.e., if you are standing
at the tip WITH THE REST OF THE WIRE BEHIND YOU, then your approach
to the screw would keep *it* on your right. If, OTOH, you were
standing at the tip with the balance of the wire IN FRONT of you,
then you would keep the screw on your left.
Or, from your analogy, whether the wire approaches you (standing
on the head of the screw) "head on" or creeps up on you from behind.
There are two references here -- how you refer to the wire
and how you refer to the screw (post).
Think of how you would explain this to "a guy off the street"
(not someone in s.e.d)
Since you do not like JL's description how about threadwards? It
goes around the screw the same direction the screw goes into the
terminal.
