Terminal Block and Ring Connectors
Discussion in 'Datasheets, Manuals and Component Identification' started by Mr Ed, Oct 6, 2017.
  1. Mr Ed
    Mr Ed
    16
    Oct 6, 2017
    Hello,
    I have to order some barrier blocks and ring connectors. How can I be sure the ring connectors will fit the screws and the space available on the barrier block?
  2. kellys_eye
    kellys_eye
    4,275
    1,147
    Jun 25, 2010
    From the specification sheet that applies to the barrier block....
    The manufacturers site will reveal all.
  3. shrtrnd
    shrtrnd
    3,816
    518
    Jan 15, 2010
    They're rated by 'stud' size.
    The screw in the barrier strip will be size '6' or '8', or whatever.
    You just need to use kellys-eye's advice and find-out the barrier strip screw (or 'stud' size), and then
    buy ring-tongue lugs that are the same size.
    Since you're asking - be SURE you buy ring-tongue lugs of the correct stud size, that ACCEPT THE AWG WIRE-SIZE that you'll be terminating the ring-tongue lugs with. The AWG wire size will be noted on each of the correct size ring tongue lugs available.
    Good luck with the project.
  4. Minder
    Minder
    3,078
    657
    Apr 24, 2015
    First you need to state the wire size in order to select the correct ring connector for that gauge, next, if you have the terminals already selected, then choose a ring dia to suit.They come 3 or 4 diameter per device.
    IOW there are two dimensions, wire gauge and terminal screw diameter in order to select the crimp terminal required.
    M.
  5. Mr Ed
    Mr Ed
    16
    Oct 6, 2017
    Thanks for the advice guys.
