G
George Herold
So I’ve got a little plastic box and I want to make connections on the outside.
I thought of a terminal block soldered to the pcb that ‘sticks’ througha hole.
But it doesn’t really work. (Well it’d work but it looks like cr@p.)
https://www.dropbox.com/s/qrhak96zjn2t12l/DSCF0027.JPG
That’s an attempt at a mock-up.
(It’s about 0.6 inches from the top of the pcb to the top of the box.)
(I’ve ordered some bigger (5mm) terminal blocks, they may be OK.)
So some kind of panel mount terminal block would be ideal.
Banana plugs are just a bit too big and clunky.
Any ideas?
George H.
PS searching digikey I found this... it’s a bit big.
http://www.digikey.com/product-detail/en/0708250/277-5906-ND/348301
Any ideas?
George H.
