Hi guys, just want to know when to prefer soldering over using a terminal block when connecting wires? And vice versa . Does it have something to do with the length of the wire that you are connecting ?
Personally, if it's hard to reach or will never need to be serviced, I solder it.
If I am working on something that is 'modular' in nature, I put any modular components on a terminal block. Makes testing and replacing nodes much easier.
Overall though, it depends on the purpose... The physical location, environment, and the signal/power you are dealing with.
