Ravenvalor
- Jan 21, 2012
- 3
- Joined
- Jan 21, 2012
- Messages
- 3
Hello,
> I would like to build a board that has 1 - 120volt/600Watt input and
> 3 - 120volt/200Watt outputs. The outputs we shall call A, B and C will
> each light up a 150 - 200 watt light bulb. Each light bulb will light
> one at a time starting with A and ending with C. This will operate
> continuously. The delay between each output will be from .25 seconds
> to 2 seconds. If you think that there is something already out there
> that can do this I would like to know about it. I would like for this design to be robust enough to run 24/7/365.
> Thank You,
> Jim
> Thank You,
> Jim
