S
Steve
Happy Holidays to all.
My neighbor has discarded an almost new 24 inch
Insignia CRT television. It is model number ISTV040922A with
a manufacture date of March 2006 but it is beyond the 90 day
warranty period. This appears to be a cheap Chinese
manufactured store brand sold only by Best Buy chain stores.
It has a problem.
The screen display appears to have alternate scan lines replaced
with dark gray (or blank?) signal information. (as if the image
data for all the odd (even?) numbered scan lines is missing
mode. The scan lines which do get displayed appear to be "normal".
The user manual does not indicate anything relative to the
television operating in a non-interlaced mode and there is no
option for changing this in the user level setup menus.
The problem occurs with both of the composite signal input sources,
the antenna input and even the user setup menus. (The
television also has component and S-Video inputs but I have
not seen what happens when these are used as the input source.)
The implication being the trouble is located in the circuits
after the input processing (cold solder joint?; vertical blanking
circuit perhaps?).
Is it likely there is a simple fix for this problem (defective
capacitor or resistor)? Is it more likely the fix will require
a chip replacement?
Probably it is not worth taking to a repair shop as the unit is
being advertised for new sale at $119 (sorry about that TV
repair techs). It seems a shame to discard an almost brand new
television, even one as cheaply made as this one, without making
some attempt to salvage it.
Steve
It has a problem.
circuit perhaps?).
a chip replacement?
Steve
