A
Andy
I'm trying to build myself a decent sounding stereo system. What I have at
the moment is a pre-amp feeding into an active crossover which then feeds
into two power amps, one for the woofers and the other for the tweeters and
mid ranges, with a passive crossover onthe tweets/mids. The problem is that
the passive crossover for the tweets/mids shifts the phasing and sounds
awful.
The stop gap solution I have at present is to use a simple 1st order
(passive) crossover on the tweets/mids, and placing a coil in series with
the woofers simply to shift the phase 90 degrees to match the other drivers.
I've used a coil value that SHOULDN'T affect the lineararity (is that a
word?) of the woofs - but my (untrained) ears tell me otherwise. I seem to
be getting a slight roll off on the upper end of the freq. range. Unless I
have other problems with my box design, which is very possible, but I want
to eliminate other possibilities first.
All passive components are supposed to be of suitable quality for
crossovers (from Jaycar).
I built the active crossover myself with a board I purchased from a bloke in
Sydney who makes them. See - http://sound.westhost.com/project09.htm
My question is;
Could I build a 2nd order passive crossover for the tweets/mids and reverse
the polarity on the woofs (removing the in-series coil of course)? Would
that make them in phase or 360 degrees out, and would that matter?
Would I be better off constructing a circuit to go between the active
crossover and the woofer amp to shift the phase?
I'm doing it this way because I was able to get the (reasonable quality) pre
and power amps at a really good price.
Pls note - I have no electronic qualifications but I am fairly technically
minded so simple(ish) answers are appreciated.
Andy
awful.
My question is;
Andy
