C
Crash Gordon
12ga Romex to all door switches.
**Crash Gordon**
| Doug wrote:
| >> I try to pull spares to everything. But even if you dont, a motion
| >> with a tamper needs 6 unless you common up the tamper, which I
| >> consider a last resort. 6 to a keypad is a no-brainer. 22/12 is real
| >> handy in residential when you're trying to conceal a lot of circuits
| >> , or going from one end of the house to the other, or pulling some
| >> protective loops out to a garage. I sent a request for a quote to
| >> Contractors wire and cable, we'll see. Probably have to take out a
| >> second on the house. js
| > You could use the DEOL option for the motions and have the tamper
| > open the loop that way you don't have to use up a zone for the tamper
| > or use the -ve as a common for the zone & tamper. With the cost of
| > zone expanders so low, it just doesn't seem as necessary to pull a
| > multi-conductor as it used to. Anyway I don't have room on my van for
| > rolls of multi conductor.
| > Doug
| Not being a residential guy, you wouldn't understand. Just so you know, we
| don't run emt in houses, so the cabling has to be neat.
| You need a bigger van.
| js
**Crash Gordon**
| > Doug
| js
