What you are suggesting is a good issue to keep in mind for the real
world (and one I had overlooked).
However, what you have actually said is not true.
There ARE such cases. In such cases, the L value will drop.
An inductance - a specific element we both referred to as L - will not
saturate. Rather it will behave in accordance with the simple
mathematical model of inductance.
Sure. If one states a fixed L for a calculation, then DC offsets
are ignored. Perhaps this is why high frequency inductors are hybrid
cores, as opposed to steel or iron as in a low frequency case.
The real-world magnetic device chosen to play the role of an inductor
can saturate, and it's something we might need to think about. However
the propensity towards saturation would need to be specified by
additional parameters beyond a simple constant value of L. While we're
at it, we should put in parasitic resistance, temperature dependence,
possible effects of external fields, and probably some other things
that I'm not thinking about.
If asked to solve a problem with an inductance, you treat it as such.
If asked to solve a problem with an inductor, you have to consider the
broader properties of that device, of which inductance is only one, and
not necesssarily a constant one.
I see what you are saying. You are declaring/regarding it as a mere
number that gets plugged into a formula. OK. In that case you are
correct... the value is immutable... however...
If one must regard the junction potential of a diode in making a
circuit calculation for a circuit which includes a diode, one must
also make calculations for the parasitic, etc. effects of other
components as well, when designing or discussing them.
The *ideal* circuit scenario is one for the classroom in which the
basic fundamentals are conveyed. After that, the instructor
immediately conveys the whys and wherefors of the REAL world
scenarios making a direct distinction between the two.
Out here, in the real world, one needs to consider real world
effects. I see from your explanation and distinction between the two
that you know this. So, for the real world...
DC offsets saturating an inductor is most certainly a needed
consideration, if the circuit so demands, just as knowing what the on
resistance of a transistor is, or the junction potential of a diode in
a circuit which contains such elements.
Out here... in the perimeter, there are no stars...
Out here... we is stoned... immaculate.
