Boolean Expression to 2-input logic gates only
Discussion in 'Electronics Homework Help' started by power13, Oct 28, 2018.
  1. power13
    power13
    9
    Oct 26, 2018
    Hello,
    I have a Boolean expression and I want to convert it to circuit with only 2-input gates and NOTs.
    x'y'z + x'yz' + xy'k' + xyk
    Is there any different approach than:
    (x'y')z + (x'y)z' + (xy')k' + (xy)k
    Thought like this:
  2. (*steve*)
    25,270
    2,718
    You could also try using de Morgan's theorem and see if it simplifies anything.
    Alternately, just implement a three input gate with two two input gates and invert the inputs as required.
    Have you created a truth table for it?
  3. power13
    power13
    9
    Oct 26, 2018
    My expression is simplified by Karnaugh map.
    Unfortunately I think de Morgan's theorem doesn't helps here.
  4. (*steve*)
    25,270
    2,718
    Excellent. What did you come up with?
  5. power13
    power13
    9
    Oct 26, 2018
    The result of K-map is this expression:
    And now I want to draw the circuit with only 2input logic gates and NOTs.
  6. (*steve*)
    25,270
    2,718
    Aaah! I thought that was what you had modeled in the K-map.
    Why not start with something like this:
    x'(y'z + yz') + x(y'k' + yk)
  7. power13
    power13
    9
    Oct 26, 2018
    Thank you for your help.
    After some reading of Boolean Algebra, I ended up with this expression:
    ( (NOT X) AND (Y XOR Z) ) OR ( X AND (NOT (Y XOR K)) )
    I think it is a good expression with 2 xor, 2 and, 2 not's.
  8. (*steve*)
    25,270
    2,718
    Just be aware that a 2 input XOR gate may not be an allowable gate. Check this out, if you can.
    power13 likes this.
