Question about implementing (boolean) function using multiplexer?
Discussion in 'Electronics Homework Help' started by s3a, Jun 16, 2018.
  1. s3a
    s3a
    Jun 16, 2018
    Hello, everyone.
    I'm studying a past exam, and I'm stuck on something, but I'm thinking that the solution of the exam for the question I'm doing (Question 1 -- 3. a.k.a. Question 1 -- c.) has a (minor) error in it.
    Question 1 -- 3. a.k.a. Question 1 -- c.:
    https://www.docdroid.net/IeyzXy3/question-1-3-aka-question-1-c.pdf
    Its provided solution:
    https://www.docdroid.net/vNlE9vP/thesolution.pdf
    My question:
    Should the part with the (4-1) MUX drawing where there is a C be a C', instead? (I know this may seem like a small question, but I just want to make sure that I'm not misunderstanding anything.)
    Any input would be greatly appreciated!
  2. Laplace
    Laplace
    1,252
    184
    Apr 4, 2010
    I used Logisim to verify the K-map. The output for the selection A=1, B=1, certainly seems to match C' so I believe you are correct.
  3. Ratch
    Ratch
    1,093
    334
    Mar 10, 2013
    Boolean expression not fully reduced.
    A'B'+ABC'+AB'D=A'B'+ABC'+B'D
    because
    A'B'+ABC'+AB'D =
    A'B'(1+D)+ABC'+AB'D=
    A'B'+A'B'D+ABC'+AB'D=
    A'B'+ABC'+A'B'D+AB'D=
    A'B'+ABC'+B'D(A+A')=
    A'B'+ABC'+B'D
    Ratch
