Help with understing how this boolean expression was sinplified
Discussion in 'Electronic Design' started by Maxim Vexler, Dec 22, 2004.
  1. Maxim Vexler
    Maxim Vexler Guest
    Please help me understanding how this boolean expression was simplified
    1. ab + ab' + a'b =
    2. a(b+b') + a'b =
    3. a*1 + a'b =
    4. a + a'b + 0 =
    5. a + a'b + aa' =
    6. a + b(a + a') =
    7. a + b*1 =
    8. a + b
    I did a truth table on both function [1] & [8], they produce the same
    result so they are the same function, but I can't seem to understand
    using what theorem / postulate can move from line 5 to 6 ?
    Appreciate the help,
    Maxim.
    Example was taken from "Art Of Assembly (DOS-16bit), Chapter 02, Page 48"
  2. Maxim Vexler
    Maxim Vexler Guest
    My point exactly!
    I don't know based on what/how he did it, but check it yourself: both
    functions produce the same result (IE they are the same function).
    What I'm trying to figure out based on what boolean algebra theorem the
    expression was simplified?
    Look :
    P4: ab+ac=a(b+c)
    P5: a+a'=1, a*a'=0
    Th3: a+0=a
    Th4: a*1=a
    F=ab + ab' + a'b
    [by P4] = a(b+b') + a'b
    [by P5] = a*1 + a'b
    [by Th4] = a + a'b
    [by Th3] = a + a'b + 0
    [by P5] = a + a'b + aa'
    [by wtf?] a + b(a + a')
    [by P5] a + b*1 =
    [by Th4] = a + b
  3. Active8
    Active8 Guest
    since aa' = 0,
    then baa' = 0
    so you put the b there so you can use that, wtf?, associative
    property? cute.
  4. Active8
    Active8 Guest
    I'm wrong, well, I was right, but it doesn't justify the wtf? step.
    a'b + aa' =
    a'b + baa' =
    b(a' + aa') not b(a' + a) or b(a + a')
    don't be surprised if there was a misprint. Doesn't make sense,
    though. Somebody will be along to either straighten this out or
    confirm wtf?
  5. Can't help you, too much eggnog to focus...
  6. mark thomas
    mark thomas Guest
    The artist formerly known as Maxim Vexler <hq4ever (at) 012 (dot) net (dot)
    | 1. ab + ab' + a'b =
    | 2. a(b+b') + a'b =
    | 3. a*1 + a'b =
    | 4. a + a'b + 0 =
    | 5. a + a'b + aa' =
    | 6. a + b(a + a') =
    | 7. a + b*1 =
    | 8. a + b
    | Maxim.
    I'll give you a hint:
    x' + xy
    = x'(1 + y) + xy
  7. Rich Grise
    Rich Grise Guest
    How does it work if you go,
    a + a'b + bb' = ?
    Cheers!
    Rich
  8. Ratch
    Ratch Guest
    "Maxim Vexler <hq4ever (at) 012 (dot) net (dot) il> >" <"Maxim Vexler
    There is mistake in step 4 and step 6. Using the absorption theorem:
    x = x+xy=x+xy+xz+x(w+v+...) , we continue the correct way.
    a+a'b= a+a'b+ab=a+b(a'+a)=a+b*1=a+b, which is what you are looking for.
    Ratch
  9. Ratch
    Ratch Guest
    hq4ever (at) 012 (dot) net (dot) il> wrote in message
    Ratch
  10. Thaas
    Thaas Guest
    Step 6 should have been:
    6. a + a'(a + b) =
    Since x + x'y = x + y:
    7. a + (a + b) =
    Since x + x = x:
    8. a + b
    In the quoted text the author would have us believe between steps 5
    and 6 that:
    a'b + aa' = b(a + a')
    Which simplifies to:
    a'b = b
    A fallacy.
  11. Ratch
    Ratch Guest
    If one knows that the identity x + x'y = x + y is true, then a + a'b =
    a + b, and one does not need to go further. Ratch
  12. Thaas
    Thaas Guest
    Yeah, I just crawled back out of bed on that realization. Still, the
    fallacy remains. The author mistyped something between 5 and 6.
  13. Thaas
    Thaas Guest
    arrrgh! You're right, it was the use of aa' for 0 from step 4 to 5
    that threw the proof offcourse. Should've stayed in bed.
  14. Fred Bloggs
    Fred Bloggs Guest
    He must be relying on some fundamental results like a=a+ab and a=a+aa',
    which are fairly self-evident and require little reasoning beyond
    definition manipulation. Then 5) becomes: a+ ab + a'b + aa' when those
    substitutions are made, and 6) obviously follows. There is no error,
    typo, or illogic- it was a departure from one simple substitution per
    line that threw you.
  15. Fred Bloggs
    Fred Bloggs Guest
    Any term in the summation can be replicated - so replicate ab.
    This is rewritten as:
    2. ab + ab' + ab + a'b
    and then
    3. a(b+b') + (a+a')b
    and then
    4. a + b
    That book was written by a moron, throw it in the trash.
