Boolean Expression help
NanyBany
May 15, 2014
12
May 15, 2014
12
Can anyone help me simplify this Boolean expression, what I got is several different results, the most recent one is:
!C(!A + A!B)
My goal is to make a 7 segment display output the decimal number based on the combination of the 4 bit input. Ex 0000 will make the 7 segment display 0. But when this simplified Boolean expression is implemented, it doesn't work. I have no idea where I went wrong, please no K-maps. Thank you for any help much appreciated.
For some reason the truth table won't post upright :/ Sorry.
[Moderator's comment: I've fixed your image so it's the right way round. --KrisBlueNZ]
Gryd3
Jun 25, 2014
4,098
Jun 25, 2014
4,098
You would need a boolean expression for each segment, would you not?
Which segment is this for?
Please tell me which segment you are working on... as the first line appears to be searching for numbers 02346789.
NanyBany
May 15, 2014
12
May 15, 2014
12
The first segment 'T' it should be searching for numbers 02356789 not 4.
Gryd3
Jun 25, 2014
4,098
Jun 25, 2014
4,098
Would a binary to 7-segment decoder schematic help you out? I didn't dig too deep mind you, so I am unsure if your table matched this diagram.
It involves a little tracing.. but you can see the inverters, and gates and or gates. Just follow the traces backward from the display and you should be able to make out the logic from each segment.
*Sorry for the lazy answer, I just figured it would be easier to look up existing work than to map it out all over again ;)
If this is not what your after, I'll sit down and map something out.
NanyBany
May 15, 2014
12
May 15, 2014
12
I appreciate the answer I really do, but I want to simplify and implement it all myself for an educational experience. I would like to know what I did wrong when I simplified the Boolean expression. And if anyone could, I would like to see their simplified solution of the Boolean expression.
Laplace
Apr 4, 2010
1,252
Apr 4, 2010
1,252
It appears that you used the identity (!B!D+BD)=1 which is not true.
NanyBany
May 15, 2014
12
May 15, 2014
12
And you are awesome, thank you. That is exactly what I was looking for. What I think is that
(!B!D + BD) = B Xor D.
If not, then what does (!B!D + BD) = ?????? Thank you again for the help.
Harald Kapp
13,700
13,700
B xor D is 1 if either B or D is 1, but not both are 1 or 0.
!B!D + BD is 1 if either both B and D are 0 or B and D are 1.
So (!B!D + BD) = B Xor D is not correct. You find the error yourself?
NanyBany
May 15, 2014
12
May 15, 2014
12
So it is XNOR then? I don't even know how to reference that in a Boolean expression. Would it be (B Xor D)'
Harald Kapp
13,700
13,700
B Xnor D = NOT(B xor D), I assume that's what you mean by (B Xor D)'.
