K
[email protected]
<snip>
I just have the WRT54G. I'd have to buy an AP, but Linksys indicates that it
only works with two APs (WAP54Gs). I don't see a way of telling my WRT54G
that it's a slave. I really don't want to buy an $80 WAP to try when Linksys
says it's not designed to work.
The only way i can see that as necessary is; if you have two discontiguous
wired lans with a wireless segment between them. Your described a situation
of wanting to print from a wireless equipped computer to a wired lan printer.
Or do i misremember? If you know the IP address of the printer you should
be able to find, ping, and use it from the wireless computer. Printer driver
installation which may be needed to find the printer for printing is a separate
issue.
True, no wired LANs[*], but the existing WRT54G has the DSL router hanging off
it. I don't really want to have to disconnect from the Internet WLAN and
connect to the printer WLAN while the printer is running.
[*] There is now but just from one computer to the printer
If i understand you correctly the DSL line comes in to the DSL router which has
wireless. There is also a wired connection from the DSL router to the WRT54G
which also has wireless.
The DSL line comes into the DSL MODEM, which is connected to the WRT54G.
Everything else is wireless from there.
I guess that the printer is wire connected to the WRT54G.
No, the printer is connected to my laptop via a wired LAN. I want to connect
the other laptop to the printer.
Two questions:
Can you connect to the Internet through the WRT54G wireless port?
Sure. That's the only way. ;-)
Can you connect to the printer through the DSL router wireless port?
No. Again, it's on the wired LAN connected to my laptop. The object is to
print from my wife's laptop, which is only connected via WLAN.
The way i understand networking this should be normally: yes, yes.
Some settings may have to be examined.
Just as I thought. We were talking past each other.
What I wanted to do was to connect the printer to the WLAN and have the WRT54G
do all the routing through its wireless port.
Now that i have a correct view of your network, install the printer driver
on her laptop and it *should* find the network printer connected to the
WRT54G. It really _is_ supposed to be that simple. It may be worthwhile
to use the printer settings and WRT54 settings (yes both) to set up "fixed"
IP address for the printer.
It needs to be installed as a shared printer, and the computers will
need to be configued for 'printer and file sharing'
What does that do? If they're on the same net they're peers, as far as the
printer goes. Of course the two computers might try to step on each other.
