Hello All,
I just successfully replaced the back glass on my Apple Watch SE 40mm 2nd Gen. The original glass happens to be not as robust as I thought. It has cracked when I fell a few times while ice skating.
This process is easier than the full back assembly replacement, But only applicable if the sensor/charging is working.
The glass edge ~1.5mm is attached to the back cover with a strong adhesive. Its dome/top part is covering the charging coil/sensor. Which is attached to the glass with less adhesive, but still needs to be cautious removing it.
The prying/opening tools T-0.1mm and Jakemy were used:
The replacement glass is bought on Aliexpress, https://a.aliexpress.com/_EGj0dHl
costed less than €15.
Glue B7000 15ml ~€2, adhesive is waterproof
The video instruction is available here https://star.aliexpress.com/post/8000036317347497.html?type=102&detailStyle=17
- Removing
- Test
- Assembling
- Clean
