Hi guys
so I got another motor on market place, sweet little find. Anyway, it has 5 wires coming out of it. I've searched the web to find schemas for it but can't find exact match (comes off a Ford focus 2004). From what I can tell the middle wire (black) is my negative and then then i would have my hi and lo on one side and my park on the other side. either way, a few questions. how can I test this before applying power to it? I presume I can damage motor if apply power to the wrong wires. In the other motor I had I could tell which one was my negative so it was fairly easy to find the hi and lo.
Second question. ground. Do I need to ground this somehow? I will be using for a prop eventually so the motor will be in a wooden box. powered by a dc converter (which that would be grounded) but wondering if I need to ground this somehow in order to make it safe
thanks
thanks
