S
SolarFlare
Modified Semantic Wave is correct.
George Ghio said:Tell us why anyone would modify a sine wave.
George said:Tell us why anyone would modify a sine wave.
We previously went through this crap with CD players.
The sampling frequency was chosen to be 44.1 kHz, well
beyond the range of human hearing. No filtering would
be needed.
Except for one thing...when they played the CD back
unfiltered, people would find their tweeters melting
for some weird reason....44.1kHz! at huge powers!
Out came the drawing board and complex analogue (and
expensive) filters were designed until one day some
smart engineer discovered they could double the freq.
in a computer and put out 88.2 kHz sampling noise and
use a less efficient and less expensive filter.
"....It depends how you count "steps"."
Indeed.
I suppose something like "the number of distinct voltage changes per
cycle" might be a good first approximation of something to call steps
and to count.
In your example I would count something like "3" or maybe "2" or "4" -
I always have trouble with boundary conditions...
In any case, it seems that the device you had was effective.
And the only thing I could imagine as having fewer steps would be a
similar device that didn't have the pause at zero...
And yet it was effective -
I wonder if it would have worked with the light dimmer mentioned
above...
A lot of ac loads are quite happy on dc. Almost anything that rectifies
the mains waveform will run fine on dc of V_mains x 1.414.
NT
philkryder said:"....We have a touch lamp that will not change
state on MSW, but will on generator"
Do you know if these new smaller Inverter style generators are a close
enough approximation for things like the laser printer?
Just how good are the "sine" like waves on them?
I thought someone was going to put a 'scope on one...
NT
It's called "engineering," George.
Nick
I don't have one (inverter/generator) to test. If it's a SW then yes, it
will work. The HONDA EM50is claims to be a sine wave unit.
Really... Wouldn't they rather modify a square wave to approximate a
sine wave? What would be the point of modifying a sine wave, when a sine
wave (or close approximation) is the required result?
Rich said:It seems pretty obvious that a mechanical generator should put out a
relatively pure sine wave - it's just this big rotating magnetic field and
a couple of coils, after all.
As a matter of fact, it's a little hard for me to visualize how someone
would make anything _other than_ a plain vanilla sine wave using just
a rotating magnet and a coil.
Thanks!
Rich
Rich said:I hope you're not serious here.
They don't make a sine wave and modify it, they make a rectangular
wave and call it a "modified sine wave" because it passes enough tests
for harmonics and crap that it will run most stuff, and they can get
away with it. ;-)
Anybody wanna do an FFT of various duty-cycle waveforms, and give us real
THD information, and how that relates to power factor, and etc, and etc,
and etc?
The one inverter I've ever had my hands on the guts of made a waveform
like this:
| | | | | etc.
And the regulator was just based on an ordinary rectifier - they didn't
care about RMS, or it was scaled to get "close enough".
But I do wonder, what does the harmonic content really do when you vary
the duty cycle?
Some years ago, in the USAF, I saw some pulses on a spectrum analyzer,
and they had some really pretty envelopes.
Rich
To vary the power delivered to a load. Chopping off part of a sine wave
cycle is a standard means of power control.
