stupid questions
psunlock
Aug 19, 2013
18
Aug 19, 2013
18
please enlighten me and pardon my silly questions thanks
1: how can i produce a 3.30 mhz rf carrier signal with modulation of 8,020 hz
2: can a normal signal generator be used in conjuction with an rf amplifier to produce
harmonic sound on 767,035 hz , how can it be heard with just an aerial?
3: which type of aerial could i use to produce 767,035 hz with an amplification of 150 to 200 watts
excuse my ignorance i am 2 days old in this field
the 3.30 Megahertz RF harmonic carrier frequency and the audio frequencies are combined or modulated together they will produce many harmonic sideband frequencies
i want to know how i can acheive this cheaply and then how to amplifiy its output by 100 to 200 watts legally of course i am in a country that has no law on these matters
Perhaps it might be worthwhile knowing exactly what you intend to do.
Some of what you ask is confused (e.g. amplification is not measured in watts, aerials don't amplify, you can't hear things with an aerial, etc...)
psunlock
Aug 19, 2013
18
Aug 19, 2013
18
thanks for replying i am trying to build one of these
http://www.rifevideos.com/aubrey_scoons_1939_rife_beam_ray.html
i have found so much disinfo on net its almost unbeleiveable but i strongly beleive that this tech works and is simple its just a question of power and rf carrier waves
any help would be loved also i would want real free thinkers help not help that you found posted by trolls or gremlins
thanks
Time for the woo-woo label:
Rife also reported that a 'beam ray' device of his invention could weaken or destroy the pathogens by energetically exciting destructive resonances in their constituent chemicals.
Rife's claims could not be independently replicated, [5] and were ultimately discredited by the medical profession in the 1950s. Rife blamed the scientific rejection of his claims on a conspiracy involving the American Medical Association (AMA), the Department of Public Health, and other elements of "organized medicine", which had "brainwashed" potential supporters of his devices.[
http://en.wikipedia.org/wiki/Royal_Rife
psunlock
Aug 19, 2013
18
Aug 19, 2013
18
ok i asked for that haha
but i have seen this tech working so i just want to clarify what is possible and what isnt in the electronic side of things
i want to produce an rf signal from 20 hz to 200 khz with a output power of at least 100 watts
i want it to be varible so maybe some sort of signal gen?
i found this scheme of an amp http://www.rifevideos.com/images/Chapter 11-2/booster.jpg
can anyone enlighten me on how powerfull it is and if it can be amplified further
thanks again
That is a class AB audio amp, and I don't see how it could possibly work since the gain of the voltage amplifier is only a little over 1, and it claims to output 66V p-p from a 2V p-p input.
I suggest that you read the Wiki article. People have died by using useless Rife machines instead of treatments that actually work.
psunlock
Aug 19, 2013
18
Aug 19, 2013
18
correct me if i am wrong but isnt that the signal input ?
the power input is 230 volts at top left ?
psunlock
Aug 19, 2013
18
Aug 19, 2013
18
such glorious disscussion and advice truely inspireing a post from wikipedia and some bull and lifes good again huh ?
forums dont grow on these principles but on free exspression and thinking
reasearch who plato and aristotle are they started the forum for alike minded philoposhy
i am very disapointed so far
and yes i know i mispell words .....
Yes, the power input is 230 volts, but that has nothing to do with what I said. If the signal input is 2V p-p and the output is 66 V p-p there must be a voltage gain of 33. But this amplifier has practically no voltage gain as drawn. Put a bypass capacitor on the emitter resistor and it might work.
In any case, it will not help you with amplifying RF frequencies.
14,279
14,279
forums like this and other electronics related ones, grow on good information and correct physics.
There's very little that you have given do far that falls into either of those 2 catagories
since you are an admitted newbie in electronics, it would be really wise for you to start doing some electronics and physics tutorials and learn correctly the way things work in the real world. Diving deep into high power transmitter projects IS NOT the way to start into electronics. Learn to walk before you try and run :)
this comment from you is just totally irresponsible....
I dont care what regulations your country has ... but power levels of 100 - 200 W at 3MHz is going to go world wide and your activities would upset many many people far beyond your country's borders
Again your lack of basic knowledge stops you from seeing the problems
if you want to do it legally ... join an amateur radio club, learn the electronics and get your licence :)
One of the tubes used there looks a bit like an x-ray tube, but the internal discharge suggests it has gas in it.
So it probably produces UV and maybe x-rays.
I wouldn't want to be within coo-ee of it when it was operating.
Simply as a safety matter, I'd recommend you not try to create one of these. Similarly, in the interests of safety, you're not going to get much help. As mentioned elsewhere there are other concerns too.
psunlock
Aug 19, 2013
18
Aug 19, 2013
18
ok well thanks for warnings and such
lets talk theoretical for now
can you tell me why 300wats 3mhz would be seen worldwide>?
thanks
Because that amount of RF at that frequency if coupled to a reasonable antenna could propagate a very long way.
It is also in a range of frequencies used for serious purposes and where the legitimate users would probably track you down and have (at the very least) some stern words with you.
14,279
14,279
........can you tell me why 300wats 3mhz would be seen worldwide>?
thanks
The fact that even have to ask that question confirms you have no idea of what you are trying to do and the intereference you would cause.
3MHz will propagate worldwide with as little as a few watts. There's a whole group of amateur radio operaters that specialise in what's called QRP operation. They work the world on 5 Watts or less. So imagine the impact you would have with 100 - 200 Watts !!!
The rest of us amateur radio operators believe life is too short for QRP only operation and we will pretty must, most of the time, us the maximum power levels we are allowed to according to our licence rules. In Australia, where I am, I'm allowed 400W PEP maximum ( PEP = Peak Envelope Power). But usually I use the maximum out of the radio ( without an external amplifier) which for most HF radios is 100 Watts.
The HF radio frequencies ... 1 MHz to 30 MHz are used for world wide propagation by commercial and amateur radio stations. These frequencies get the long distance because they reflect very well off the ionospheric layers that surround the earth high up in the atmosphere.
cheers
psunlock
Aug 19, 2013
18
Aug 19, 2013
18
fantastic info so far and yes you keep poitning out that i dunno what i am talking about but its a field i got into recently so bear with me
my other question is if i have a signal generator which gens a signal varibly from 0.01 hz to 8mhz and it has 2 channels is it possible to mix the channel output ?
like for example one channel produces a carrier wave and the other produces a piggyback signal ??
i suppose what i am getting at is can i bypass a radio oscilator and connect the signal gen directly to my homemade rf amp
thanks again
p.s the aerial i would have used would be localized somehow ;)
13,769
13,769
0.01 hz to 8mhz
8mHz = 8 millihertz - certainly not what you mean. 8 Megahertz is abbreviated 8 MHz. Take care to use the the right capitalization to ensure common understanding.
On top of this I doubt that you will find a generator that goes from 0.01Hz to 8MHz.
14,279
14,279
if you mix 2 signals, 5MHZ and 3MHz, then you will have the 2 sums of those 2 frequencies ... that is 2 output signals
5+3 = 8MHz and you will also have the sum of 5-3 = 2MHz
there will also be harmonics present.
In a radio receiver or transmitter we will decide which of the 2 output signals it is that we want and we will filter out the other one. We will also have a low pass filter that will filter out the harmonics that occur at intervals up the radio bands ( spectrum).
The last thing we want is a "dirty" transmitter that is spewing out signal all over the spectrum as well as the one frequency we want to use
At 3 MHz, a tuned antenna is large ... even just a basic wire antenna. extremely difficult to make any sort of antenna that would have only localised coverage
psunlock
Aug 19, 2013
18
Aug 19, 2013
18
0.01Hz - 10MHz(UDB1210)
Resolution 0.01Hz(10mHz)
Frequency Stability +/-1x10-6
Frequency accuracy +/-5x0-6
Sine wave distortion <=0.8%(reference frequency is 1kHz)
Trinagle linearity >=98%(0.01Hz-10kHz)
Rise and fall time of square wave <=100ns
Square Wave Duty range 1%-99%(digital control mode)
14,279
14,279
that's not a real problem these days Harald :) tho it would be unnecessary in most situations .... 10kHz and up is more common and more useable
that's a nice little DDS synth :)
DDS = Direct Digital Synthesis synthesiser
my main signal generator in my shack goes from 10kHz to 8.4 GHz
gets used for a lot of my microwave experiments and tuning up of gear
