Soundstream Amp
amateuramp
May 18, 2012
May 18, 2012
Hello all. For some years now I have owned a Soundstream 2000d monoblock car amp. It has served me well. However it blew out 3 capacitors. The amps factory capacitors were (G-Luxon 2200uf 80v tw85c (m) 702p ) with dimensions of 30mm high by 25mm diameter wide and 12mm through board electrode distance. Size is an issue. I have two questions for anyone who might be able to answer them. I would like to know if a capacitor with a rating of 2200 uf 100v 105c, instead of 2200uf 80v 85c, could be used and would it be better, worse or of no consequence. The flexibility of voltage may improve my chances of finding a close size. The other question is, where can i buy them?
AmateurAmp
The ratings you suggest for replacement will probably work better than the originals.
Capacitors have a lifetime, and those ones you had may have come to the end of theirs.
I don't know where you are, so I can't recommend a source, but look at sites like digikey, farnel, element 14 etc.
14,271
14,271
yup you can use them no probs :) the 85C and 105C are temperature ratings
you dont need to be a rocket scientist to realise that 105C is better at handling higher temps ;)
cheers
steve beat me to the reply haha I typed it out and got called away work interfers with leisure time far too much!!
amateuramp
May 18, 2012
May 18, 2012
great info-appreciated
I reside in West Palm Beach, Fl. As for digikey the one they offer is to tall. I am still working on finding one.
Amateuramp
Digikey probably have *many* capacitors that meet these specs. Have you gone through all of them?
Also give Mouser a go.
how's this one?
Did we pick the same one? No. Mine is 25mm wide and 30mm high. CocaCola's is 25mm high and 30mm wide.
CocaCola
Apr 7, 2012
3,635
Apr 7, 2012
3,635
There are also a few possible options on Ebay from China if you search for 100v 2200uf
