Your assumptions about what you can and cannot do have gotten you into this
mess, so you might want to consider taking the good advice given before
I'm not sure in what spirit you meant this.
Isn't an assumption an educated guess based on previous experience,
observations, knowledge of similar devices... How can you ever fix
anything, or even USE anything without making basic assumptions about
it.
When I use a toaster I ASSUME it's not going to melt through the floor
in a thermite like blob or explode like a lump of C4 destroying most
of the house.
When I fix, say, a camera out of an SM placement machine. I ASSUME
it's going to have (several) power supplies, data lines for
controlling focus/exposure etc, either composite video or video with
separate syncs - PROBABLY 50/60Hz vertical and around 15kHz horizontal
or it may be some freaky digital interface that MIGHT still have
obvious sync information.
It's NICE to have full service manuals, schematics, hotline to the
engineers in the company who designed the thing... but it's not always
possible.
That said, I ALWAYS appreciate GOOD advice from any source.
making any more. Hopefully you recorded exactly everything that you
adjusted so someone who is familiar with these sets can sort out the
Don't *ASSUME* people are stupid. I *KNOW* there are "dangerous"
options in the menu, I am only interested in geometry adjustments.
All I want to do is improve the annoying pincushion distortion, center
the picture and MAYBE change that very dark grey background into
black.
I'm sure you've seen these menus, they're very friendly. Proper mixed
case english descriptions, no obscure abbreviations. Anybody who
understands the concepts of pincushion, trapezoid etc. adjustments
(anybody who has fiddled with a newish monitor) would have no problem
understanding it.
Maybe we need a secret handshake of the "I can talk about bandgaps,
potential wells and quantum tunnelling without my head exploding.
Shame about anybody listening" kind.
problem. It might take a system reset and realignment or perhaps component
But how do you find someone who's GOOD at doing that?
replacement. Don't proceed without at least getting the service and
training manuals.
It's not always that easy...
Anyway, I took another look at it today to clarify the fault (always
handy when trying to fix something or seek correct help).
With an RGB input, it is possible to adjust the horizontal position.
This is now correct and the picture is centered and square.
With a broadcast DTV signal any attempt to adjust the horizontal
position causes the setting to jump to zero (from where it was set
while in RGB mode) and stick there.
With the picture centered in RGB mode the DTV signal displays around
15mm too far right. It would be nice if there is an adjustable offset
between DTV and RGB but if not I'll leave the RGB input centered as
this is used far more for DVD/DVR/Satellite.
I've read brief suggestions about the grey/black thing but nothing
concrete.
All of these problems are with the "Wide" mode. "Smart" mode is good
enough and I'll leave realigning the 4:3 and 14:9 modes for now as
these are rarely used and I wouldn't want to make any unnecessary
adjustments
Dave.
