Hi, I'm working on a power supply from a cheap TV I want to repair.
The power supply work fine but most of the time, after few minutes, a ferrite core radial inductor start to make a loud and highly pitched noise. I already replaced the main capacitor on this power supply, the TV wasn't working at all when I got it but now with the new capacitor it work fine except for the noise. I tried to crazy-glue the coil to reduce the sound but it didn't worked. The inductor is filtering the 24V power line that supply the backlight and the motherboard.
My questions are:
- Is it possible that the problem come from capacitors? Or I have to try to identify and replace the inductor?
- Is it possible that any other faulty part cause the coil to resonate like this?
I also noticed that the two capacitors close to the inductor (capacitors connected between the 24V line and the ground) became hot. I have a multimeter if I need to test any voltages.
I hope this is clear enough, English is not my first language.
Thank you!
My questions are:
Thank you!
