power pad whine
John Larkin
OK, if you're going to stuff high-dissipation parts into absurdly
small packages, power pads are a good idea.
ftp://66.117.156.8/PowerPad2.jpg
(at least it's hard to bend the pins)
But why do only a tiny minority of datasheets mention what the pad is,
or isn't, electrically connected to?
John
S
Spehro Pefhany
John
That's one of those rhetorical questions, innit?
I'd guess it's going to be the substrate, if anything, but that and
two bucks will get you a cup of coffee.
Best regards,
Spehro Pefhany
John Larkin
It was a whine.
Seems like very roughly half are insulated, either by a di semi
process, or some sort of actual insulator. And the rest seem to be
mostly substrate, so must be floated or strapped to the most negative
chip supply. For the ungrounded cases, one must find a way to conduct
the heat out of the board from what may be a small pour.
A small latte is up to $2.75 here, but worth every devalued cent.
John
W
WJLServo
John
Call me paranoid; even if the vendor DOES spec slug connection, I do
an ommeter check....
W Letendre
John Larkin
W Letendre
A fellow paranoic. I do, too.
John
B
Ben Jackson
If your power pad is whining perhaps there's a problem with your paste
mask. ;-)
