problem with dsc 1616 power keypad
Discussion in 'Security Alarms' started by NilsCA, Oct 22, 2007.
  1. NilsCA
    NilsCA Guest
    Hi
    I'm trying to setup my dsc 1616 system - did the wires, etc.
    Now ... if I turn on power the keypad (PK5501) shows the little keypad/
    finger symbol on the left and a unset clock to the right (with
    blinking colon)
    Pressing any key on the keypad makes the clock go away ... it returns
    to - - : - - a couple of seconds later.
    If I press hash (#) for 2 seconds or so the keypad beeps 3 times and
    the little warning symbol lights up on the right (none of the 4
    symbols was one before), the little keypad/finger on the left
    disappears.
    Not typing anything the keypad returns to the state above.
    If I type star (*) or hash (#) I get another beep - the latter seems
    to return the keypad back into the state above ... it's weird and not
    at all what's expected.
    I've reset the the console via the bridge between PGM1+Z1 ... no
    change.
    Anyone know how to unwedge this?
    Nils
  2. Frank Olson
    Frank Olson Guest
    All DSC products need to have the clock set when you first power them
    up. Enter *6, then your four digit master code, then 1, then the time
    (in 24 hour format) hh/mm then the date mm/dd/yy then "#" twice. Read
    the freakin' manual. :)
  3. alarman
    alarman Guest
    Maybe it IS rocket science after all.
  4. NilsCA
    NilsCA Guest
    Hi Frank
    thanks for the reply - yeah, I should have mentioned that I tried that
    already.
    I press
    * 6 1234 1 1212 121207 # #
    there's no beeps, no change in display, no acknowledgement at all, no
    change to the keypad showing the little program symbol on the left
    If I go
    hold # (3 short beeps, light goes on, programming symbol goes away)
    then it beeps once somewhere during that sequence - light goes off,
    programming symbol appears again.
    I still get nothing - the keypad keeps on only showing the little prog
    system left
    I fear there's something not right with the keypad. Any way to hard-
    reset it (tried the console as mentioned already)?
    Cheers and Thanks for trying
    Nils
  5. NilsCA
    NilsCA Guest
    Hmm, have to reply to myself - got some more info
    I've managed to unwedge the keypad by
    press # (beep) hold (3 beeps)
    press 1 (beep) hold (3 beeps)
    the programming symbol goes away and the keypad is as I'd expect. Set
    the clock, program a zone, test the system (*6 MMMM 4), door chime,
    etc. all works
    After 10 secs inactivity the panel switches back to showing the clock
    and keypad symbol on the left, doesn't take input, no door chime, no
    ready symbol.
    I've done all factory default resets [993-999] ... anyone have another
    good RTFM pointer I'm missing?
    Thanks a lot
    Nils
  6. NilsCA
    NilsCA Guest
  7. Crash Gordon
    Crash Gordon Guest
    another boat anchor
    Crash Gordon
    -------ouch------
    <I feel like I'm diagonally parked in a parallel universe>
    | Mark Leuck wrote:
    | > | >> Hi
    | >> keypad/ finger symbol on the left and a unset clock to the right
    | >> (with blinking colon)
    | >> disappears.
    | >> change.
    | > Yea get someone who knows what they are doing and can read
    | > instructions to work on it
    | js
    | - The bigger they are, the harder they fall.
    | ( Also, the harder they bite, punch, and kick.)
  8. alarman
    alarman Guest
    We need to read up because you programmed the keypad with an invalid
    partition assignment?
    js
  9. alarman
    alarman Guest
    Fat-fingering: <slang>
    1. Tinkering with electrical/mechanical devices without the slightest
    inkling of what one is doing.
    2. Rendering said equipment inoperative through direct action in spite of
    gross ignorance.
  10. motley me
    motley me Guest
    Sounds like you have the keypad set as a global keypad.
    Set the address to 11.
    It's in the manual
  11. NilsCA
    NilsCA Guest
    yes, that's the trick - thanks for your helpful post motley me
    Cheers
    Nils
  12. NilsCA
    NilsCA Guest
    Hey alarmman
    I'm in a good mood so I'll spell it out for you:
    yes, I'm a newbie who had a question - I got friendly help to try to
    diagnose it (in the end I found the solution myself actually)
    you on the other hand don't like to help newbies, as a matter of fact
    you don't keep it for yourself but make that perfectly clear with your
    snotty answer; apparently you think you're an "expert of some sorts"
    while your diagnosis ends up being wrong ... wow
    That leaves me as a newbie and you as a pretty unfriendly person who
    doesn't know it all even though you're full of yourself ... maybe you
    can still lighten up a bit, help some old lady across the street, make
    some friends, sharpen your skills - good luck
    Cheers
    Nils
  13. NilsCA
    NilsCA Guest
    sorry, another follow up :)
    I mixed you up - you didn't provide any solution at all actually. So
    please scratch
    you can keep your expert hat and don't read up. Only your unhelpful,
    snotty attitude to work on ;)
    Cheers
    Nils
  14. alarman
    alarman Guest
    Hey, dumbass
    The fact remains you don't know what the **** you're doing, didn't RTFM, and
    misprogrammed the system. You gonna deny that now?
    Then, you told me that I needed to read up. What a laugh.
    I'm willing to help anyone who isn't so lazy that they can't read the
    instructions. You are typical of a lot of the losers who blow in here and
    want your hand held, then get mad when you're taken to task for being a
    complete idiot. Software/network/computer guy...right.
  15. alarman
    alarman Guest
    Still not reading before you act I see. Maybe you need to work on that.
