Polarised C8 Inlet Power Connector
14,268
14,268
tricky one huh,, Farnell dont even have it.... I have a few of them around home that I have stripped off old equip. They are common on a Denon brand of CD player where both the polarised style you want and the non-polarised fig-8 style are used.
one reason over the years why I have spent much time stripping gear for bits :)
ikrananka
Jul 10, 2009
12
Jul 10, 2009
12
I cannot believe how difficult these are to find. Don't suppose you'd consider selling some of those you've stripped off old equip?
ikrananka
Jul 10, 2009
12
Jul 10, 2009
12
Hey - they just might work. The thickness of my panel is just over 2mm so should snap-in (panel is plastic so could thin it slightly if necessary).
The only problem I can see is that the item linked above has connections for a PCB. I need to solder direct to wires - do you think soldering wires to these PCB connections would be difficult and/or not-recommend?
Thanks so much for finding this item.
KMoffett
Jan 21, 2009
723
Jan 21, 2009
723
Soldering to them should not be a problem...they're meant to be soldered anyway.
Ken
