Tam/WB2TT said:
It will work for a small load, like an antenna rotator. Put a 1n4XXX diode
across each capacitor, so that it is never reverse biased. Since only one
capacitor is in line at any given time, you do not have to double the
capacitor value. I would first look for a non polarized capacitor. 2 uF oil
filled 600V caps used to be common in the surplus market.
If im not mistaken the capacitors will charge up so that the diodes no
longer conduct and therefore you still have 2 capacitors in series (both
biased corectly 99% of the time), so need twice the value.
Without the diodes the capacitors should self rectify so that they both
charge up initialy and once charged only ever being reverse biased just
enough to cancel the leakage current in the oposite direction and so will
stil work ok, however this is not so good for the capacitors so the diodes
might help.
You have to watch the ripple current and temperature rise and consequential
derating due to temp, electrolytic capcitors are often current rated for
smoothing rectified dc so expecting to have a voltage ripple of considerably
less than their rated voltage at 100hz, a full voltage ripple at 50hz might
exceed the ripple current rating.
They can explode quite spectacularly if anything goes wrong and lifetime is
an issue if worked hard, a big voltage safety margin might be a good idea.
ie use at least 500vdc.
Amongst other types already sugested you can get X-rated caps at 1uf
(designed for supresuon accross line) quite easily I dont know how cheaply,
these will undoubtedly be safer and more reliable.
If there is any inductance ie using for motor start you have to watch for
much higher voltages due to resonance.
Colin =^.^=
