PLL LMX2326
H
Hervé
HI,
I plan to use a LMX2326 (NS) with a large bandwidth VCO (zcomm v674me02).
I don't want to use an active loop filter, but my VCO needs Vtuning from 1
to 14 V.
Can I use a passive loop filter when connecting VP (on lmx2326) connected to
+15V dc ?
Regards
Herve
R
Rene Tschaggelar
Hervé said:
HI,
to 14 V.
+15V dc ?
A passive loop filter operates on the voltage or current coming out of
the phase detector. If the LMX2326 allows that, then it should work.
Rene
A
Allan Herriman
HI,
to 14 V.
+15V dc ?
The datasheet says VP abs. max voltage with respect to ground is 6.5V
(and recommended max is 5.5V).
Regards,
Allan.
John Miles
HI,
to 14 V.
+15V dc ?
Nope. The charge pump voltage pin only accepts up to 6 (maybe 7?)
volts. You'll need an outboard gain stage.
-- jm
