Microwave Door Switch
xmen
Jul 31, 2015
3
Jul 31, 2015
3
My Frigidaire brand microwave door switch is broken. The specs that was written on the door switch itself says
"16(4)A 250V". I bought a door switch from ebay, but the specs that's written say "16(3)A 250V". Can i use it? I already put the one that I bought, it fits but I never try to turn on and use the microwave. Does it gonna work?
Kiwi
Jan 28, 2013
471
Jan 28, 2013
471
This is a European standard. The first number is the resistive load. The number in brackets is the inductive load. A is Amps.
16(4)A 250V = 16 Amps resistive load, 4 Amps inductive load, 250v.
Alec_t
Jul 7, 2015
3,591
Jul 7, 2015
3,591
I wouldn't risk it. The microwave is a largely inductive load.
davenn
14,265
14,265
those are maximum ratings for the switch
no designer in their right mind would use a switch in a safety situation like that, where the switch would be running
at it's full ratings
and it would not be taking a big inductive load .... what load were you referring to ????
xmen
Jul 31, 2015
3
Jul 31, 2015
3
and it would not be taking a big inductive load .... what load were you referring to ????[/QUOTE]
So what do you think about 16(3)A 250V? Does it gonna work on my microwave. Thanks.
Kiwi
Jan 28, 2013
471
Jan 28, 2013
471
Can you measure the current through the switch?
Can you buy the correct switch from Frigidaire?
davenn
14,265
14,265
So what do you think about 16(3)A 250V? Does it gonna work on my microwave. Thanks.[/QUOTE]
there should be no problem
Martaine2005
May 12, 2015
4,953
May 12, 2015
4,953
Nobody in their right mind would put a 4 amp switch with a 4 amp load!
The switch is way above the MAX ratingh. USE it, Itr will be fine.
As Dave Said , That is the Maximum rating for that switch.
Use the one you boought., It will work just fine.
Martin
xmen
Jul 31, 2015
3
Jul 31, 2015
3
Thanks a lot Dave, Martin, I really appreciate the help. Now I'm confident that my microwave is safe to use. Gob Bless!
