E
[email protected]
We use an inverter to make three phase power from single phase in the
shop. The inverter has been working quite well, all the CNC machines
working properly, until recently. Then one of the machines kept
shutting down because of over voltage to the VFD that drives the CNC
spindle. It turns out that three of the four filter caps on the output
of the three phase inverter power supply failed. These caps were rated
60 mfd +or - 8%. The failed caps measured 17 mfd and were really hot.
The company who makes the inverter sent us new caps and all seems to
be well again. Almost. I used a Tektronix 465B scope to look at the
power coming out of the inverter before and after the caps were
replaced. The noise on the waveform was reduced by over 75% after the
new caps were installed. It still looks good. But the machine that was
getting overvoltage alarms on the VFD spindle drive is getting them
again. Not as near as often, maybe once or twice a day instead of ten
or twelve in just a few hours. When I put the scope on the inverter I
did see voltage spikes but they were fast and I'm not sure if they
were just artifacts. But if I can somehow document or record these
spikes then maybe I can find out if they are from the inverter or the
single phase coming in. Is there some cheap way to do this with a
computer? Maybe using a the sound card or something?
Eric
Eric
