Johan Kahn said:
Hi group,
Is there anywhere or anyone that can make 2 layered PCBs if I have the
PCB design in Protel format?
by 2 layer pcb's I mean it has tracks on both sides. and is it
possible to get ones with about 4 and 6 layers too?
Board size is about 150mm x 100mm
TIA
There certainly is - a quick search in yellow pages revealed
East Coast Circuits
16 Yampi Way Willetton WA 6155
ph: (08) 9457 6388 Printed Circuits
map
Jemal PCB
5 Forge St Welshpool WA 6106
ph: (08) 9356 1997 Printed Circuits
advert map
Print N Etch
Unit 3/ 7 Macadam Pl Balcatta WA 6021
ph: (08) 9240 1972 Printed Circuits
map
I have used East Coast and Print N Etch in the past. 4 and 6 layers is no
problem these days.
Be prepared for it to cost you plenty though......it'll cost you a few
hundred just for one board. Especially for plated through holes. These guys
have web sites and generally have some good info on basic capabilities and
basic design criteria.
A company I use regularly now is BEC Manufacturing in Queensland, simply
because I find them cheaper. But you have to buy by the 'panel'. But you can
put as many different designs on one panel as you like. BEC has costing on
their site to give you an idea of how much it will cost you.
http://www.becman.com
The choice is yours,
Richard
There are other resources elswhere that I'm sure others on this NG could
point you towards.
