M
Martin Griffith
I find it nearly unbelievable some of the horseshit you uneducated
twits spew.
Personally I prefer Marmite to Brasso, I suppose you like Vegemite
Martin
twits spew.
Yup.. Does sound like that'll work and perhaps worth a try..
Gold is a relatively soft metal. Using a pad that is just harder than
the gold but softer than the copper (or plating on copper) will help
reduce wear on the copper.
I know scotchbrite scuffs copper which means something in the
scotchbrite is harder than copper..
Household cleansers (ex Javex) contain chlorine compounds but I don't
know if that will react with gold.. (I'm not a chemist!)
However chlorine gas will. How fast..I dunno..
It's interesting, it takes only 1% chlorine to saturate water. Max
solubility is at 9.6C.. Anymore and it gases.
This can be a good thing too. I suspect chlorine has much more
reactivity with gold at 9.6C temp than with copper..
So.. chilled water saturated with chlorine and etch the board is my
guess... I have no idea if that'll work..but seems like a start.
Joke...Perhaps you could just plop the pcbs in a chlorinated public
swimming pool for a few days..
(I dunno if that'll work..)
D from BC
We have boards that inadvertently ended up with hard gold finish. As a
result we have 50 microinches of gold causing all kinds of headaches at
assembly.
We asked to have the extra gold stripped off but I was told it was not
possible.
Is there no way to dissolve the gold off? Otherwise we have to get another
batch made and they're expensive. Mercury bath? Hot cyanide? Microtome?
Have an immersion silver finish over the gold!!! Argghgghgh anything!!
...and do not forget environmentally and people friendly Mercury as well
as acidic Cyanides...
On Fri, 12 Oct 2007 11:35:02 -0700, in sci.electronics.design
I'd try Brasso, don't know what the US equivalent is.
http://en.wikipedia.org/wiki/Brasso
Will your stupidity ever cease?
How about Aqua Regia?
Rich
I suppose it's a bit coarser tha jewllers rouge, I've used Brasso toBrasso. ;-)
But I don't know if I'd try to _remove_ metal with it - if there's
any abrasive in it at all, it would have to be very, very fine.
Cheers!
Rich
Brasso. ;-)
Cheers!
Rich
What else would aqua regia disolve? BTW in WW2 one nobel prize winnerThat's item #6 on my list.. HCL and HNO3 3:1 ratio which is called
Aqua Regia..
D from BC
Erase it:
http://www.officedepot.com/ddSKU.do...iqueSearchFlag=true&Nr=100000&Ntk=all&An=text
Good Luck!
Rich
clean scrathes on polycarbonate/ perpsex windows for 16*2 LCDs, takes
some time, these day's I would use teethpaste and an electric
teethbrusher
Since gold is softer than copper.. Maybe a copper powder can be used
as an abrasive to remove the gold.
Guessing..
Copper powder + paint thinner??
Maybe the paint thinner can act like a lapping lubricant.
(Brasso has some sort of hydrocarbon..just by the smell.)
I picked paint thinner because it's oily, evaporates, easy to get and
it's cheap.
Copper powder + graphite ???
Ewwww...conductive abrasives on pcb's...but anywayzz...
Copper wool (found in grocery stores) is harder than gold but as hard
as copper (1) so it might qualify as a lapping pad material.
(1) Is PCB copper tempered?
D from BC
Lets call the whole thing off (song reference to potatoe)Toothpaste
Toothbrush
Toothpaste
Toothbrush
I got curious and found a few net references that it's recommended to
remove gold (ex: rings) before going in swimming pools..
Remove gold jewelry before entering swimming pools. The chlorine in
the water will erode gold jewelry."
Erase it:
Good Luck!
Rich
Thanks, it's good to be appreciated, an interesting link , but as
Linus said
"Intelligence is the ability to avoid doing work, yet getting the work
done."
