C
ChairmanOfTheBored
Gold is one of the least reactive metals. The classic reactant is aqua
regia. I doubt that a bit of chlorine in water would have much effect.
And anything that eats through gold will go wild when it hits the
copper.
Gold is only second to Platinum where oxidation effects come in.
Both could stand a hundred years at ambient and not tarnish one iota.
They are more than a little immune to chemical attack as well.
Soldering involves heat. Dissolution of these metals during soldering
would not occur were it not for the heat involved. This is why one
should always solder with as low a temp process as can possibly be
tolerated while still achieving proper wetting, and good
micro-crystalline solder joint structure. High heat increases
intermetallic contamination in ALL cases.
