R
[email protected]
How would you measure the temperature of a concrete floor with a non
contact method? The object is to turn on the floor heat a few degrees
above freezing and relative to floor temperature. In other words a
non contact thermostat set up to keep the floor from freezing. Non
contact is desireable to prevent the sensor from being corroded by
road salt and crap the cars haul in the winter. The present setup
uses a conventional wall thermostat with a minimum temp setting of 50
degrees. In the winter it turns on the heat unnecesarily any time the
door is open for a short time. Drilling a hole in the floor for a
sensor is risky since it is unknown where the floor heat tubing is
located. Would like to do this for < $50. Any suggestions for
sensors, etc appreciated.
BobS
BobS
