E
emma
To create source of magnetic field. You only need wires as
the current passing thru them can create it. The electric
field in the wires is null because there is a cancellation
inside the positive lattice and electrons.
I'd like to build a very strong source of electric field
only. Can I use two big kitchen plates and connect each
of them to positive and negative of a car battery? Would
this create electric field in the middle.
Pls. mention all sources that produce electric fields
with minimal magnetic field present. Beside the
capacitor concept. How else could you creates source
of electric field where the electrons charge become
bare and no cancellation from the atomic lattice.
Does this mean there are positive and negative sources
of electric field that can be built using circuits.
For example, if you force out electrons from a certain
material, does it produce a positive electric field
from the positive ions left? What materials can do
this?
Thanks.
emma
this?
Thanks.
emma
