DSC Alarm Pager Option
B
Hi All-
I am using a DSC 864 to monitor some non emergency functions. I have
the system working great with a pager, but I want to have it use the
paging feature of my cell phone instead. I have a number to call to
page the cell phone, a different number than my cell number. The
problem is that the cell pager number requires two '#' at the end of
the string, rather than the one '#' that the panel sends. Is there any
way to get the panel to send another '#'???
Thanks! Bob
B
Matt-
Thanks for the suggestion - I posted the note over there. As a matter
of interest, how did you do it on your 832??
Bolb
M
Matt
Bob -
I don't remember the exact sequence, basicall I went into programming
mode and filled out the communicator dialing section.
If you download the 832 prog. manual; it lists the steps.
Manual available at:
http://www.aesecurity.com/dsc_manuals.htm
F
Frank Olson
Bob said:
Hi All-
Thanks! Bob
To enter another "#" sign you would program your phone number as follows:
Section 301 (1st phone number):
While in programming key in [3], [0], [1] then your phone number (example)
[6], [0], [4], [5], [5], [5], [5], [5], [5], [5], followed by [*], [3], [3],
[#] (the "*" sign puts the panel into "HEX" programming mode and the "3's"
are "HEX C's" that simulate the tone the "#" sign makes on your telephone
dialpad.
Please review page 24 of the 5010 manual or page 23 of the installation
manual for the 5020 (version 3.0).
B
Frank-
Thanks for the help, but I already tried this. I need the extra "#"
after the zone info is sent, the last thing sent before the panel hangs
up, not in the dialing string. If I put the "#" in the dialing string,
it causes my cell phone voice mail to thing that the entry is done and
it hangs up.
F
Frank Olson
Bob said:
Frank-
it hangs up.
Hmmmm... CID would probably do this (or some other DTMF type signal)
although I haven't tried this. You might have to "play around" with the
different codes and tones to achieve what you want... Mark Leuck is our
resident "expert" on programming... :))
M
mikey
Hi Bob, (still haven't used any of that mat yet :)
What do you mean the # that the panel sends?
To use a pager with DSC, I just use pager format and enter the pager number
followed by EEEB pause pause pause * to send..... you might try
followed by EEECEC (C is the #)
