Jeremy D. Grotte
Going to try out the 'big paper cutter' later on, if that doesn't work, I'll
find a machine shop around here with a good sized metal shear and see what
happens. Thanks for the info...
JDG
JDG
enough.Rileyesi said:Use the 'bast' saw you have available to you and then use a belt sander to
smooth the rough edges.
Personally, I've found a shear to be the best, if you can find one wide
