cutting pcb
Discussion in 'Electronic Repair' started by Patt, Mar 20, 2006.
  1. Patt
    Patt Guest
    What do you use to cut a perforated circuit board? I need to cut a roundish
    piece from a bigger piece.
    Patt
  2. Guest
    Nibble cutters work pretty well, or abrasive or carbide rotary bits.
    The latter make a nasty mess tho. I've used a bandsaw, but if the blade
    is dull it takes forever to cut through FR4, and it makes the edges all
    feathery.
  3. Yukio YANO
    Yukio YANO Guest
    I've always used a Jeweller's Saw. It looks like a small Copping saw.
    Look in a Hobby store under Lapidary Supplies and Jewellery making. Buy
    a Dozen blades of a couple of pitches at a time. Remember to mount the
    blade to cut on the PULL not on Push as a western Carpenter Saw.
    Yukio YANO
  4. G
    G Guest
    Howdy Patt......I usually use a powered scroll saw (a hand coping saw
    does the same job) and finish up lightly sanding the edges (400 grit) if
    required. Making a cut-out of a pcb can be done the same way.
    Gord
  5. andro000
    andro000 Guest
    I use an xacto laser saw for the bulk of the cutting. Finishing inside
    corners with a jewlers saw like the one mentioned above. I coat the
    jewlers blade with bees wax to avoid binding. I then finish the edges
    with 320 sand paper.
  6. andro000
    andro000 Guest
  7. default
    default Guest
    Hole saws for round pieces. Tin snips work well for straight cuts, or
    nearly straight. Saber saw with a narrow blade and large offset to
    the teeth. It's a little hard on the blade if you do fiberglass - but
    a paper cutter will make straight cuts.
