Building a basic USB device?
Discussion in 'Electronic Basics' started by [email protected], Feb 18, 2006.
  1. Guest
    Greetings, all.
    I have a requirement for getting some external sensor-data (possibly
    analogue, possible digital, not sure yet) into a PC (Linux, not
    Windows).
    This will need to be a USB connection, as it needs to be easily
    assembled by an untrained user.
    Can anyone recommend a good place to look for initial information about
    creating a USB device, alternatives, etc?
    Basically, I'm not sure where to start. Is there such a thing as a
    generic USB controller that I can integrate into a circuit? Am I
    barking up the wrong tree completely?
    Thanks.
  2. Bob Monsen
    Bob Monsen Guest
    You can buy USB cards here:
    http://www.futurlec.com/USB.shtml
    Regards,
    Bob Monsen
    I know not with what weapons World War III will be fought, but World
    War IV will be fought with sticks and stones.
    Albert Einstein
  3. Chris
    Chris Guest
    Hi. To work on making a USB interface, get "USB Complete: Everything
    You Need to Develop Custom USB Peripherals", Third Edition by Jan
    Axelson. You could also look at the Jan Axelson/Lakeview Research USB
    homepage for supplemental information, as well as other weblinks.
    http://www.lvr.com/usb.htm
    Good luck
    Chris
  4. Don McKenzie
    Don McKenzie Guest
    there are a heap of variants at:
    http://www.dontronics.com/cat_index_hard.html#usb
    all the items based on the FTDI devices have Linux drivers.
    may give you some ideas.
    Don...
    Don McKenzie
    E-Mail Contact Page: http://www.dontronics.com/e-mail.html
    Micro,TTL,USB to 1.5" color LCD http://www.dontronics.com/micro-lcd.html
    USB,RS232 or TTL to VGA Monitor http://www.dontronics.com/micro-vga.html
    World's smallest USB 2 TTL Conv http://www.dontronics.com/micro-usb.html
  5. Leo Meyer
    Leo Meyer Guest
    have a look at this one:
    http://www.flightsim.com/cgi/kds?$=main/howto/mind.htm
    This one is Human Interface Device driver compatible which is present on
    almost every OS. Gives you 6 analog and 28 digital inputs with a minimal
    effort. Should be enough for most applications. (Haven't tested it though.)
    Regards, Leo
  6. Guest
    Thanks guys, that's exactly the sort of info I need to get started.
    I'm completely out of my depth, so it will be an interesting learning
    experience :D
    Basically I need to get data from several environmental sensors to a
    black-box monitor PC (sbc/embedded/etc) for ultimate presentation via
    http. I think the sensor-data is probably going to be from analogue
    varying-resistance devices, so I may need to build a small component to
    enable multiple different types of sensors to interface with the
    monitor PC.
    I'm new to programming anything with "real" devices, rather than
    data-only services like websites etc, so this should be an interesting
    project!
  7. Chris
    Chris Guest
    Good. You may want to look at the Lab Jack, a USB-interface device
    with built-in 20 digital I/O, 8 ea. 12-bit analog inputs and two 10-bit
    analog outputs. It's got a lot of other features. They do have Linux
    drivers, but they primarily support the Windows environment. If the
    hardware is appropriate, for $119 in single quantities you can just
    wire up your terminal blocks, plug the LabJack into the PC USB, and
    move on to the programming issues. It's worth checking out:
    http://www.labjack.com/labjack_u12.html
    Good luck
    Chris
  8. Bob Monsen
    Bob Monsen Guest
    Those futurlec guys are also selling some kind of web based sensor thingy,
    which you might want to take a look at.
    http://www.futurlec.com/Web_Control_Board.shtml
    Regards,
    Bob Monsen
    He who cherishes the values of culture cannot fail to be a pacifist.
    Albert Einstein (1879 - 1955)
  9. Bob Masta
    Bob Masta Guest
    Circuit Cellar magazine has had some hands-on articles
    in the last year or so, at least in the dead-tree version.
    You might check what they have on their Web site.
    Best regards,
    Bob Masta
    dqatechATdaqartaDOTcom
    D A Q A R T A
    Data AcQuisition And Real-Time Analysis
    www.daqarta.com
    Home of DaqGen, the FREEWARE signal generator
