bigone5500
- Apr 9, 2014
- 712
- Joined
- Apr 9, 2014
- Messages
- 712
Has anyone ever had any luck making a 24v power supply from a computer PSU?
Should be able to use the -12V line and +12V line.Has anyone ever had any luck making a 24v power supply from a computer PSU?
Would this be a problem Kris?
I was hoping that it could be done somewhat easy. I am only looking to get a couple amps @ 24vdc.I haven't done it but I can tell you what you need to do.
You need to re-wind the 12V secondary of the transformer with twice the number of turns. You can remove the 5V and 3.3V secondaries, so you'll have plenty of room on the bobbin.
You may need to change the rectifier diode(s) on that rail because their voltage ratings may not be high enough. You'll have to change the smoothing capacitors to ones with higher voltage ratings.
You'll need to change the voltage feedback circuit so that it monitors the new rail instead of the 5V or 3.3V rail like it did before, and change the voltage threshold from 3.3V or 5V to 24V.
It would be REALLY helpful if you could find a schematic for the power supply so we can check that there's nothing else funny or special about it that might cause a problem. Having a schematic would also make it easier to specify what changes are required.
How many amps are you hoping to get from the 24V rail?
Oh crap! Why didn't I think of one of these? I think I have one!
Yes it is possible. I described this in post #2 on this thread.I'm just curious. Was it possible to rewind a ferrite transformer with 1:2 winding ratio. primary will be connected to original ferrite transformer of for 12V winding. This will result 24V on secondary winding . Just add new components filter circuit and rectifier to produce 24V.
Well, the supply I thought I had was actually from an old HP printer and is rated at 30vdc @2.5A. I don't know if I could use this or not.there ya go
tell us how ya get on
