ATX psu repair
Discussion in 'Troubleshooting and Repair' started by JohnBG, Feb 18, 2017.
  1. JohnBG
    JohnBG
    7
    Feb 18, 2017
    hi, i am trying to repair old atx psu,and i need some help.
    it wont start, when i short green and red just clicks once.
    No fuses are blown, and nothing appears or smells burnt.
    checked 4 diodes, 2 big condesers, three primary transistors (13007), secondaru condensers(just bigger ones, marked blue), three diodes looked like transistors and all ok. there is 310v on primary condensers, and 5v on pin 9 is present. ic is AT2005
    what can i do next? thanks
    [​IMG]
    [​IMG]
  2. davenn
    davenn Moderator
    13,983
    2,015
    green and red doesn't sound right
    usually green and black ... with green being the PWR_ON wire and black being 0V
    confirm that on your PSU pins that the green wire IS THE power on wire
  3. JohnBG
    JohnBG
    7
    Feb 18, 2017
    green+black, i wrote wrong
  4. Bluejets
    Bluejets
    5,537
    1,165
    Oct 5, 2014
    Some also need the brown wire connected to the 3.3v line.
  5. JohnBG
    JohnBG
    7
    Feb 18, 2017
    i was using it with green+black as power for led strips 12v, so i think that brown is not necessary
    also when connected to mobo, wont start pc
  6. davenn
    davenn Moderator
    13,983
    2,015
    that's not right
    Green is a power on ... monitoring line ... it's not a power supply line
  7. JohnBG
    JohnBG
    7
    Feb 18, 2017
    i wil have to learn english better. i used psu as power for led strips, black and yellow are 12v right? green and black shorted, brown was not in use.
    davenn likes this.
  8. Bluejets
    Bluejets
    5,537
    1,165
    Oct 5, 2014
    Sounds like you made a wrong connection and fried something in the power on section.
  9. JohnBG
    JohnBG
    7
    Feb 18, 2017
    green+black to turn on, and yellow is 12v for led strip power, nothing is wrong
    davenn likes this.
