E
Eeyore
Christian said:Therefore I have to supply an average power of 40W/0.9 = 44.4W at the
internal power rail. Choosing 16V as the internal voltage when the AC
supply is used gives me an estimate for the transformer with
PTrans = 1.2 * 2.8A * 17 (2 * 0,5V for schottky) = 57,12VA
You can't do that. Because the load on the transformer is non-sinusoidal, the
rms load is greater than you imagine (see crest factor of waveforms).
http://en.wikipedia.org/wiki/Crest_factor
Because the peak power will only be used for short times I though about
using a 50VA toroidal transformer. The one which came to my mind is form
talema, the 70083 (approx 20$ for a single unit). Or is this is to low I
would go with the next bigger size rated at 80VA with a diameter of 90mm.
80VA would probably be OK.
Graham
