Convert 24vdc charger into 125vdc charger
Ali baloch
Oct 18, 2019
Oct 18, 2019
I have 24vdc, 20A battery charger. Now I need a 125vdc,10A charger. May I convert my existing 24vdc into 125vdc charger
73's de Edd
Aug 21, 2015
3,629
Aug 21, 2015
3,629
Your unit is built with power transformer-power semiconductors-power diodes and E-caps that max out at 480 Watts power capability.
Your request would be demanding a total of 1,250 Watts . . . . . .no can do.
Ali baloch
Oct 18, 2019
Oct 18, 2019
If I minimiz my requirement upto 3A, means 375w. Is this possible in this condition? If yes then what I have to do pls..
duke37
Jan 9, 2011
5,364
Jan 9, 2011
5,364
There seems to be two posibilities.
1. Rewind the transformer to give the required voltage (expensive) and change the diodes (cheap).
2. Add smoothing capacitors (1mF/A?) and use a boost convertor. I have not investigated high power convertors.
7,682
7,682
Just out of curiosity, what are you going to charge with a 125V charger?
