Winfield said:
First indication that the above is what Pooh Bear was disagreeing with,
and it comes long after I killfiled the little pest.
Guy, your statement a few days ago, which precipitated the argument,
"Back to the topic, 3dB is also the amount of drop you get when you
have the output impedance and the input impedance matched, which was
common in the days of transformer-balanced audio lines," was wrong.
You are correct. Too bad it took so long for anyone to reference
the actual incorrect statement. Instead I kept posting things like
"Half the voltage equals -6dB. Half the power equals -3dB.
Double the voltage equals +6dB. Double the power equals +3dB."
and I kept getting strong disagreement and abuse when I did so.
A simple "yes, that is correct, but what you said *before* was
in error" would have avoided a lot of trouble, but instead I got
a load of "You are wrong" replies to the correct statement above.
(Typo flame deleted)
I should also point out that, when talking about power as opposed
to voltage, the incorrect statement...
....is under some conditions, *still* incorrect if you just change the
3dB to 6dB. The obvious question is "drop from what starting condition
to what ending condition?" Assume the ending condition is matched Z.
If the starting condition is a near-infinite-Z load, close to zero
power is being transfered as the starting condition, so changing to
a matched Z system is a large gain in power transfer, not a drop.
What I was thinking of when I wrote the above was the case of the
starting condition being a near-zero-Z source. I was thinking of
the way Joule misapplied Jacobi's theorem and concluded that an
electric motor driven by a battery or dynamo could not be more than
50% efficient. Edison & Upton showed this to be a bad assumption
when they made a 90% efficient system by making the source Z very low.
