Why does longer probe cable reduces bandwidth
Discussion in 'General Electronics Discussion' started by 00135599, Aug 23, 2014.
  1. 00135599
    00135599
    4
    Aug 23, 2014
    Why does longer probe cable reduces bandwidth of the probe? Does it mean the higher frequencies won't be transmitted? Is the reduction applied always only on higher frequencies? Why? What's the physic of this?
  2. OLIVE2222
    OLIVE2222
    690
    25
    Oct 2, 2011
    Supercap2F likes this.
  3. 00135599
    00135599
    4
    Aug 23, 2014
    I was reading this document, when found the note about reducing bandwidth of the probe with longer cable. I will continue reading, then, and try to find explanation later in the text. Thanks.
  4. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    00135599 likes this.
  5. Merlin3189
    Merlin3189
    250
    69
    Aug 4, 2011
    I think this is why you use a x10 probe on the end of the cable. Then you can adjust the serial capacitor to match the cable (& input) parallel capacitance.
    Without a probe with serial capacitor, there is only parallel capacitance, which attenuates signals proportional to frequency and this effect is worse the longer the cable.
  6. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    Yes and its series capacitor. And this is the reason x1 probe has lower bandwidth because you have shorted out the capacitor at the tip.
    Adam
