Yenka and PCB Creation
Nala
Feb 21, 2015
24
Feb 21, 2015
24
Hi
I am looking for some help specifically relating to the YENKA software.
My single problem is that when adding a 4017 IC to a circuit it presents a symbol representing the IC yet there is no where to add a +Voltage to the 4017 symbol. As a consequence when using the PCB engine to design the layout non is added so the IC is not connected to power. The simulator seems to know it should be connected but the PCB engine does not.
Can anyone advise how to overcome what seems to be a simple problem!
Any help appreciated is is driving me crazy !!!
kellys_eye
Jun 25, 2010
6,514
Jun 25, 2010
6,514
Can you edit/create components? You might be able to modify the file through such a facility.
Nala
Feb 21, 2015
24
Feb 21, 2015
24
Thanks for your help, I thought it would be something simple and it was. You simply add a Vdd connector to the supply you wish to connect to you IC and it does it automatically.
