Voltage Controlled Voltage Source (VCVS) - Piezo Buzzer
bcavan
Oct 18, 2017
4
Oct 18, 2017
4
Hi, I am trying to power a Piezo Buzzer between 3.3VDC and 5VDC.
The voltage is being adjusted so the sound is low (at 3.3VDC) and loud(at 5VDC).
My attachment can be a little misleading. Alarm_low doesn't suggest the volume is low, just the number of beeps. Same holds true for Alarm_medium and Alarm_high.
I'm trying to figure a way to add a circuit like a Voltage Controlled Voltage source as observed in my attachment. Can anyone offer some advice?
Brian
  • Circuit.pdf
dorke
Jun 20, 2015
2,342
Jun 20, 2015
2,342
Welcome to EP.
What specific Piezo Buzzer are you using?
bcavan
Oct 18, 2017
4
Oct 18, 2017
4
Hi there, attached is the buzzer I'll be using.
Brian
  • Buzzer_MSS5MMG.pdf
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
That datasheet doesn't indicate that a lower voltage will work, but I presume you've tried it yourself.
What input signals will you use to set the voltage? Do you want to supply an equivalent voltage, or one of a couple of logic levels, or something else?
A simple solution is to apply a voltage to the base of an npn transistor, where the collector is connected to the +ve supply and the load is between the emitter and ground. The voltage applied to the base is approximately 0.6V higher than that applied to the load.
bcavan
Oct 18, 2017
4
Oct 18, 2017
4
Hi Steve, yes I tried it with lowering the voltage to about 3.3VDC and raising to 5VDC and it was clear the buzzer was louder at 5VDC. I have given more thought to using perhaps a PWM signal from the main controller. The main controller is a Windows 10 module (COMEX). My customer requested roughly four settings, High, Medium, Low and off. This gave me the idea of perhaps using a PWM signal from the comex module.
I did contact the buzzer manufacturer and they did advise that lower the voltage to the buzzer from 3.3VDC to 5VDC will work fine. As I mentioned in my post, the question is how to do that effectively.
(*steve*)
25,510
25,510
So, what signals do you have available?
PWM will need to be filtered or it will modulate the sound from the buzzer.
(*steve*)
25,510
25,510
If you set up an adjustable 3 terminal regulator, you could use a couple of digital outputs to turn on or off a couple of MOSFETs which select the resistor between the adj pin and ground. This would allow you to digitally select the voltage passed to the buzzer.
Alec_t
Jul 7, 2015
3,591
Jul 7, 2015
3,591
Here's an option for PWM control.
The blue trace represents PWM duty cycle.
dorke
Jun 20, 2015
2,342
Jun 20, 2015
2,342
This isn't a "simple buzzer".
It is classified as a "Medical Alarm",it has a full length tune and repetition rate.
You can hear the tune on this page.
In the application information (pages 9-10) it is explained how to get the 4 states you need "Off,Low,Mid,High", simple enough.
Alec_t
Jul 7, 2015
3,591
Jul 7, 2015
3,591
Aarghhh, I missed that :oops:. Good catch.
So, three digital outputs suitably driven, plus some 1A rated output transistors (BJT or MOSFET), plus a couple of diodes will do the trick, and PWM isn't suitable.
(*steve*)
25,510
25,510
From what I understood, the difference in behaviour desired is different from that obtained by asserting the different signals on the alarm itself.
Audioguru
Sep 24, 2016
3,656
Sep 24, 2016
3,656
Does a medical person need to learn the 20 melodies to determine the medical problem? They all sound like a buzzer. Why not have the device speak the medical problem in words like airplanes do? Pull Up- Terrain; Bank Angle; Stall etc.
(*steve*)
25,510
25,510
"RETARD RETARD". <-- Why is the aircraft calling me retard?
Alec_t
Jul 7, 2015
3,591
Jul 7, 2015
3,591
O.k. So PWM* could be used after all (per post #9), in combination with the mode selection (per post #11).
Edit: Filtered PWM.
Audioguru
Sep 24, 2016
3,656
Sep 24, 2016
3,656
You should not use PWM on the alarm, you can use filtered PWM to set the voltage of an LM317 voltage regulator.
